cdzo72
Apr 18, 2020Apprentice
Amazon appstore being blocked
Hello to all. Ok, while I am connected to my Orbi WiFi, any device is unable to access the Amazon appstore. I have disabled Disney Circle and Netgear Armor, leaving the Orbi to run without 3rd party a...
cdzo72
Apr 19, 2020Apprentice
You have to download the app from Amazon directly I think. To answer your question though, no, they are not the same thing. There is the Amazon Shopping app and then there is the Amazon Appstore app, but that's not a problem, opening the app and getting as far as seeing the apps is possible, just won't let me download anything using the app on my handheld devices. But seeing as the problem persists on the Firesticks accessing the same apps, just from a difference and device, the destination they both call to must the same or under similar urls.
The issue is that when you actually get into the apps on the Appstore and choose Install a message pops up saying that the payment has been declined.
On my FireStick, the problem manifests its way that it blocks the traffic from the Firesticks being able to load apps from the Amazon Appstore. On Firesticks below the Recents row there is a row that has all your installed apps. Also, if you long press the Home button, a screen comes up that allows you to see your apps kinds of like the apps screen on an Android phone or iPhone... with the FireStick connected to my Orbi WiFi I get a message that says authentication error occurred...
If I disconnect ANY of these devices from Orbi, the problem disappears. My cell phones if connected to their 4G networks can then install from Amazon. The FireSticks, if I connect them to the HotSpot on any of my phones, that app row I mentioned and the apps section are then populated.
Once I switch back to Orbi WiFi, the problem reemergers.
CrimpOn
Apr 19, 2020Guru - Experienced User
I seem to recall a recent post about Amazon Prime streaming that was resolved by eliminating a "Double NAT" problem.
Is the Orbi (a) in "router" mode, and (b) connected to an ISP modem that is also a router?
- cdzo72Apr 20, 2020Apprentice
I am running a dual wan setup through an Edge Router Lite 3. Running into that are my 2 ISP FTTH connections which are set to bridge only. NAT masquerade is setup for the dual wan setup on the EdgeRouter. The EdgeRouter provides a static local IP to the Orbi. How do I know the Orbi is the issue... any other router I connect behind the dual wan works perfectly without touching a single setting in the EdgeRouter. Zero issues of any kind for VOIP calls, streaming, downloading, zero issues. I connect the Orbi and issues immediately arise.
- FURRYe38Apr 20, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
cdzo72 wrote:I am running a dual wan setup through an Edge Router Lite 3. Running into that are my 2 ISP FTTH connections which are set to bridge only. NAT masquerade is setup for the dual wan setup on the EdgeRouter. The EdgeRouter provides a static local IP to the Orbi. How do I know the Orbi is the issue... any other router I connect behind the dual wan works perfectly without touching a single setting in the EdgeRouter. Zero issues of any kind for VOIP calls, streaming, downloading, zero issues. I connect the Orbi and issues immediately arise.
Neither FTTH modem can be put in Bridge Mode because I get an IPTV subscription from each BUT both modems have the radios shutoff and neither transmit WiFi signals NOR hand out DHCP addresses. Each is hardwired to it's perspective boxes and each with a dedicated LAN port that goes to the EdgeRouter for the dual wan. I assure you the setup IN FRONT of the Orbi is correctly configured, NAT rules, firewalls, the works.. it has ALL BEEN DONE by the techs that provide the services and I will reiterate, I have 3 OTHER ROUTERS that I can put in place of the Orbi and NONE of the 3 give me the issue I am looking a solution to. There is NOTHING wrong with double NAT as long as it's correctly configured and it's also a must when using a DUAL WAN configuration.
AP mode on the Orbi is also NOT an option considering the ONLY reason I purchased Netgear Orbi instead of Unifi Mesh, the real deal, was for the Circle parental controls and BitDefender integration, BTW both have been disabled on the Orbi trying to get this issue resolved and it made no difference.
