dja2k
Jul 30, 2020Aspirant
Amazon Echo and Google Home are both delayed
Recently I have problems with Amazon and Google's home speakers. They wake up but take long to respond, mostly throwing out the "something went wrong, try later". The Orbi system is up and running,...
Jul 30, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
