marcosscriven
Aug 17, 2018Aspirant
Amazon Echo showing as wired connection
Peculiarly the connection list on my Orbi shows the Amazon Echo as wired, when it’s definitely wireless. Any ideas how to fix that?
- Aug 17, 2018
Hi marcosscriven,
Have you tried disconnecting and reconnecting the Amazon Echo? Also, have you tried power cycling the Orbi?
Please let me know if the issue persists and if so, provide a screenshot and I will go ahead and report it to our engineering team.
Christian
Christian_R
Aug 17, 2018NETGEAR Employee Retired
Hi marcosscriven,
Christian
marcosscriven
Thanks Christian_R - restarting the Orbi fixed that. Peculiar that it should show up as wired when it's never been wired.
- Christian_RAug 17, 2018NETGEAR Employee Retired
