marcosscriven's avatar
Aug 17, 2018
Amazon Echo showing as wired connection
Peculiarly the connection list on my Orbi shows the Amazon Echo as wired, when it’s definitely wireless. Any ideas how to fix that?
  • Christian_R's avatar
    Aug 17, 2018
    Hi marcosscriven
    Have you tried disconnecting and reconnecting the Amazon Echo? Also, have you tried power cycling the Orbi?
    Please let me know if the issue persists and if so, provide a screenshot and I will go ahead and report it to our engineering team.
    Christian
