Kristy838383
Dec 07, 2018Follower
Amazon Fire tv stick not showing internet
We just set up our new Orbi system of a router and 2 additional satellites. We are plugging the Orbi router directly into an AT&T modem router 5268AC (which was just not putting out a big enough signa...
Dec 07, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
raamahuja
Dec 03, 2019Initiate
3rd Option to disable all radios on original modem and setup Orbi Router as AP worked like a charm.
Life saver...
