Kristy838383
Dec 07, 2018Follower
Amazon Fire tv stick not showing internet
We just set up our new Orbi system of a router and 2 additional satellites. We are plugging the Orbi router directly into an AT&T modem router 5268AC (which was just not putting out a big enough signa...
Mstrbig
Sep 15, 2020Master
The Firestick is still seeing the original router's tables. You need to forget your WiFi Network and re-establish a connection.
Navigate to Settings.
Use the Firestick remote to navigate to the Settings menu and select the Network option.
Select Your Network.
Locate all networks and press the Menu button for more options. ...
Forget each Network. ...
Search and Reconnect to your Orbi WIFI Network.
- CaseykitSep 15, 2020TutorGot it! In fact, it was being denied access by Orbi which I found under access control. Everything works well now. Thank you so much for all your help.
