UnspeakableRage
Sep 16, 2020Aspirant
Amazon FireTV won't stay connected to Netgear Orbi Wifi 6 Mesh
The Orbit Wifi 6 is great. No more dropped next camera feeds, the entire family can stream, etc. The only problem we have is that our Amazon Fire TV will disconnect - usually after 1-3 days - an...
Mstrbig
Sep 16, 2020Master
What FireTV device do you have?
Depending on what FireTV device you have, it is more than likely overheating.
Firesticks will do it ifthe little cable is not used. Faulty or 3rd party power supplys will cause this as well.
