zcastagna84
Feb 01, 2021Tutor
Amazon prime video thinks VPN is active
Hi, within the last couple of days, any device on WiFi that tries to open prime video is greeted with a message saying a VPN is active. This is not the case. Chrome casts, iOS devices, laptops, etc al...
zcastagna84
Feb 02, 2021Tutor
I checked on that website you mentioned as well as the Orbi management site and both have the same IP starting with a 204. I don’t see that in the range of IPv4 addresses on the wiki page you linked. That means no double NAT right? No forum on desert iNet. That discussion you found from a couple years ago, that’s interesting. A cursory read through it seems like they set up new equipment and Amazon’s VPN algorithm was erroneously flagging things as VPN. The guy in that Reddit post, who claimed to be a network engineer said as much in his situation too. However, wouldn’t the ISP be ruled out if I can connect into the modem and have it work?
https://www.reddit.com/r/amazonprime/comments/bgetdg/prime_video_thinks_im_on_a_vpn/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
Feb 02, 2021Guru - Experienced User
No double nat then.
