lskbaker
May 13, 2021Aspirant
Amcrest Cameras, AT&T WiFi Router and Orbi
I cannot see my Amcrest cameras with Orbi as my WiFi. See them fine with AT&T WiFi. How do I work around the Orbi settings to see my cameras again?
May 13, 2021Guru - Experienced User
LIke vajim says, what att gateway is it?
If it has its own integrated router, it causes a double nat.
What is Double NAT? | Answer | NETGEAR Support
this can create the issue you're running into.
options?
1. put the att in passthrough/modem only mode
2. put the netgears IP address into the att devices dmz
3. put the netgear into access point mode.
(only use one of those methods)
- lskbakerMay 13, 2021AspirantI have more than one camera. AT&T modem is bgw210.
