lskbaker
May 13, 2021Aspirant
Amcrest Cameras, AT&T WiFi Router and Orbi
I cannot see my Amcrest cameras with Orbi as my WiFi. See them fine with AT&T WiFi. How do I work around the Orbi settings to see my cameras again?
lskbaker
One router brings internet in and WiFi is off and Orbi is set for wifi
May 13, 2021Guru - Experienced User
shutting off wifi doesn't disable router functions or put the att device in modem only/passthrough mode.
Try using one of the methods described above.
- lskbakerMay 13, 2021AspirantThe Orbi is already in AP mode. You said one of the three right? So I’ve put the Orbi in AP already and that didn’t help me connect to camera. Do I then try passthrough mode or adding the IP address and not both of those?
- plemansMay 13, 2021Guru - Experienced User
after the orbi is in access point mode, reboot the complete system (router, att device, cameras)
