turnerm05
Dec 09, 2017Luminary
Android 8 Crashes Orbi
I've been tracking down an issue where my Orbi just suddenly drops wifi and reboots. I've isolated it to be associated with an Android device running 8.0 or higher. And I've proven it turning off w...
turnerm05
Yes!! Definitely happens when waking the phone up. Almost guaranteed to happen in that situation.
I know that it doesn't happen on Android 7. I've confirmed that.
Super annoying! I've had to leave my wifi off in order not to drive the family crazy!
I just upgraded my Orbi to 2.1. I've turned my Pixel wifi back on to see if the issue still exists. In guessing it does. Will test over the next few days.
electronics18
Dec 09, 2017Star
Yes it is still happening for me on 2.1, and 2.1 seems to have an issue with WiFi passwords, possibly ones that have a $ sign in them, when it reboots none of my devices will connect anymore. I have to change the password to something else using the web interface and then change it back using the app, then it is fine till the next reboot. So for now I just have forgot the network on my phone.
- turnerm05Dec 09, 2017Luminary
So far I haven't had any reboots on 2.1 but I'm sure they are coming - just a matter of time. It almost ALWAYS happens first thing in the morning when I first pick up my phone. So I'm expecting a reboot tomorrow morning.
But it's been stable all day since updating to 2.1.
- loomis1975Dec 09, 2017Luminary
I am not having a problem with an original Pixel running 8.1 Beta crashing the Orbi router.
I am also not having a problem with a Nexus Player android TV running 8.0 doing anything either. But I'm not sure if that one ever really goes to sleep and wakes up the same as a smartphone.
The Pixel is on 8.1 BETA, but it keeps trying and failing to install a further small update to 8.1 BETA, not sure if that is related to the lack of interferring with the Orbi.
Interesting that you have two devices on 8.0 that aren't causing issues. This makes me wonder if it's a particular App that's causing issues. That could be particularly difficult to troubleshoot!!
