turnerm05
Dec 09, 2017Luminary
Android 8 Crashes Orbi
I've been tracking down an issue where my Orbi just suddenly drops wifi and reboots. I've isolated it to be associated with an Android device running 8.0 or higher. And I've proven it turning off w...
turnerm05
Dec 11, 2017Luminary
My Orbi is rebooting when waking up my Pixel again. Didn't even last a full day before it happened.
Very odd issue! No client device should be capable of causing the router to crash/reboot.
electronics18
Dec 11, 2017Star
Yea, I am not understanding this either, there is definitly an issue with the Pixel phones and mesh wifi systems in general as is evident by this thread, but it seems Orbi is the only one that completly crashes from the devices.
- btonetboneDec 11, 2017GuideI have a Google Pixel 2 XL running 8.1 and an Orbi system (RBK50) currently running 2.1.1.12. I have not had any unexpected reboots on my Orbis.
- electronics18Dec 11, 2017StarHmm, I haven't gotten 8.1 pushed to me yet, I was going to join the beta to get it but it seemed from this thread it was still present in 8.1. I am wondering if is is carrier specific maybe. What carrier to you have? I have at&t and it mostly happens when I wake the phone up so maybe something with mobile data and wifi.
- turnerm05Dec 12, 2017Luminary
You may be on to something. I was poking around in the Developer Options and I noticed that the setting "Mobile Data Always Active" is enabled. After reading a little bit about this setting it seems that it wasn't enabled by default prior to 8.0 and for some reason it's now enabled on SOME phones but not all. It's enabled on mine.
From my limited reading it appears that this setting allows for fasting switching between mobile networks and wifi. I wonder if this is somehow creating an IP conflict on Orbi which causes the reboot?
I'm out of the country this week but will toggle this setting to off and see if it resolves my issue. Won't be able to test until this weekend.
- jasonjasonDec 12, 2017Guide
I tried this this morning and the "Mobile Data Always Active" did not make a difference.
I have RBK53 on newest v2.1 firmware (issue began before v2.1, but has been worse on 2.1)
I have 2 Pixel 2 XL phones. Mine is on release 8.1 (Mobile Data Always Active ON). My wife's is on 8.0 with November security patch (Mobile Data Always Active OFF). We have been experiencing disconnections of both satellites and all devices connected to Orbi at least every 2 hours for the past several days. This is in AP mode. An Asus router serves as the router and other devices connected to it seem unaffected.
Last night, after reading this thread, I turned off wifi for both phones. We went 10+ hours without a disconnection. I turned on my phone wifi (8.1) and wifi dropped across the network within 2 minutes. I turned wifi off again. I waited over 1 hour, with no disconnection. I toggled Mobile Data Always Active to OFF on my phone and connected to wifi again. Within a few minutes, the network dropped again.
I disconnected my phone (8.1) from the network and connected my wife's (8.0). After about 20 minutes, I left for work and the network had not disconnected. She will be home most of today, so I'll report back after work wether the network stayed connected for 9+ hours with her 8.0 phone connected and my 8.1 phone gone.
- btonetboneDec 12, 2017Guide
My reboot-free system involves a Verizon Pixel 2 XL on 8.1. I unchecked "Monile data always active" in the developer settings menu soon after installing 8.1 last week.
- electronics18Dec 12, 2017Star
Yea I just checked, mine was never enabled. It seems after a reboot of my phone it doesn't cause the crashes, at least for a little while and on my old Pixel that is on the same version of Android it never happens, that phone has no carrier now, which is why I was wondering if it had something to so with the carrier, I know AT&T doesn't like unlocked devices. Have to test more and see.
- Only1ZDec 15, 2017Aspirant
My Pixel 2 XL on 8.1 is making my Orbi reboot. Each time it wakes up is causing the problem. It's super annoying because all my smart home devices don't always come back up functioning correctly so I have to manually play with them to get them to work correctly (usually around 28 devices on at one time). I just got the Orbi as well so I'm brand new to this (replaced an R7000). Why would a client ever cause a router reboot? That's crazy. I went into the Developer Options on my Pixel 2 XL and unchecked the "Mobile data always active" but that doesn't seem to have worked but I haven't rebooted the phone yet. I'm going to reboot it now and monitor. When I pull my phone off wifi, everything works well.
- turnerm05Dec 15, 2017LuminaryI've tried everything. Nothing helps. Netgear has really hosed things up.
My solution... Ditching Orbi and going back to Eero. I'll lose some speed but everything will be rock solid. - Only1ZDec 15, 2017AspirantAfter changing my phone setting in developer options to not stay connected to mobile network on wifi AND rebooting my phone, I have had no disconnects tonight. I suggest people try it.
- turnerm05Dec 16, 2017Luminary
I've had the false sense of security that I had solved the issue many times. I'm guessing that when you woke up this morning and woke your phone up the Orbi crashed? If not then I'm all ears. However, I'm on my way to Best Buy in a few minutes to pick up the Eero. Even if your Orbi is stable now who knows what will happen on the next firmware update. I'm just tired of dealing with it and my family is tired of have Wifi disappear all the time.
- Only1ZDec 16, 2017AspirantMy wife just woke her phone up after waking up this morning and like clockwork the Orbi rebooted.
- turnerm05Dec 16, 2017LuminaryYea... I would've almost bet money on that happening unfortunately. Sorry man.
I'm literally standin in line with my Eero now. Looking forward to stability again. - turnerm05Dec 16, 2017Luminary
Got me Eero up and running with no issues. Super solid and super reliable. Yes, I gave up a little speed in the far corners of my house and yes, it's an overall more expensive solution BUT... it's super stable.
If I have to chose between stability and absolute speed then stability wins all day, every day. I've got gigabit service so the difference between 300mbs and 180mbs is insignificant. It's easy to get caught up in maximizing speeds but we have to remember that in 99% of cases, anything over 50mbs is overkill for almost any application.
I truly wanted Orbi to work but Netgear clearly has some big turds to work out. And when you consider the superio customer support of Eero it's a no brainer. In this case I'm going with the underdog. I wish I had stuck with them to begin with. I left them for the Orbi which was a huge mistake.
- btonetboneDec 16, 2017GuideSorry to hear your experience was not good. I've been Rock solid with my Orbi, hosting a handful of Rokus, Android devices (including my Pixel 2 HD), security cameras, a pair of laptops, Nest, a bunch of additional peripherals, and my SmartThings. No drops at all. I wonder if maybe it is a quality control thing, and some folks simply got dud Orbis?
btonetbone I do not doubt that. I had an excellent experience for multiple months. Zero issues and rock solid performance. Then suddenly things went south. And unfortunately it only take a week of instable performance to bring a household of users to its knees. I'm tired of fighting with it. Eero is super solid, although a little slower. But stability is a huge premium - especially once you lived on the other side of the fence.
- Only1ZDec 16, 2017AspirantSounds similar to my setup...one Roku TV, Android TV, Chromecast, Smartthings, Hue, WeMo, multiple PCs, HDHomeRun Prime, PS3, etc. I usually have 28 or so devices connected at one time. I'm still in my 30 day return window and have requested an RMA from my vendor just in case. I literally can sit here and watch the router reboot when my Pixel phones (my wife and mine) wake up from a decent period of inactivity.
Only1Z Exactly! It took me a few days to narrow it down to my Pixel but once you realize what's going on it's super easy to prove it.
The most baffling part to me (and I've said this probably a billion times at this point) is that a client device is forcing a router to crash/reboot. That's just unheard of and completely ridiculous. We could wait another year or two for this one issue to be fixed but in that time another 5-6 would surface.
Most people want their routers to be set and forget. Orbi is NOT that sort of solution.
- voodooboy22Dec 17, 2017AspirantAnother case; can 100% confirm that my Pixel 2XL on 8.1 is causing my RBK50+2 satellites to go nuts almost every single morning. I suspected it was one of our Echo Dot devices, but a few days of disconnecting it didn't solve the problem. On a whim, I decided to turn off the WiFi on my Pixel 2XL overnight (because I would find it off WiFi almost every morning) and boom...no dropped WiFi today morning. I tried to get it to join the network and a few mins later, the entire network drops.
- tcommanderDec 17, 2017Guide
Pixel XL (8.0) and Pixel 2 (8.1)
I tested tonight a lot of setting suggestions out there and none have fixed the issue. I can say that it is during Satellite to Sattelite handoff that the reboot happens. I don't know what might help fix this that is phone related as I've turned off everything but wifi itself. I have a 2 unit system so unplgging the sattelite should stop the reboots.
I'm considering a Google Wifi with wired backhaul or Linksys Velop (Potentiall wired backhaul) as options. I figure at this point, if they work like **bleep** with my phone at least they don't kick the family off the internet.
Anyone tested running just the main base with a Pixel Phone?
- Only1ZDec 17, 2017AspirantI haven't but I took my phone off wifi. No reboots!
I'm waiting for my vendor to approve the return so I at least have that option. - rhester72Dec 18, 2017Virtuoso
Weird!
I updated to 2.1 for about an hour, fell back to the 2.0 KRACK beta, and still had intermittent restarts I couldn't understand.
Sure enough...I got a Pixel 2 XL last week, and it's running 8.1.
That explains it...sort of, but seriously, what the hell?
- ModxmvDec 21, 2017Aspirant
I am having the same issues on a brand new system. I replaced Google Wifi for other issues that I won't go into, but it wasn't rebooting when I wake a phone up.
What version did this start at? Is it stable in previous releases?
Right now I am leaning to returning the Orbi system and putting my Google Wifi back in.
- Only1ZDec 21, 2017AspirantNot sure when this started as my Orbi system is brand new and it has worked this way for 4 weeks now. What was wrong with the Google WiFi?
After a power outage the Google Wifi Mesh would collapse and have to be rebuit. If I got lucky and everything synced up after power returned, the wireless speeds would be ~.5mb/s. Basically unuseable. I've had numerous troubleshooting calls with Google. One thing that bugs me is that the obfuscate the logs so you can't actually see what's going on with the system. There was no information of any use to me what was going on.
- turnerm05Dec 21, 2017Luminary
When I gave up on Orbi I was highly considering Google Wifi but I was reading JUST enough stuff like this to keep me from doing it.
I went with Eero and it's been just completely rock solid for me. However, I'm starting to be of the opinion that the whole mesh wifi thing is just rife with complications so what may work for one person may not work well for another.
It's fairly new technology on the consumer side so hopefully as it matures we will see a great improvement in the stability.
