turnerm05
Dec 09, 2017Luminary
Android 8 Crashes Orbi
I've been tracking down an issue where my Orbi just suddenly drops wifi and reboots. I've isolated it to be associated with an Android device running 8.0 or higher. And I've proven it turning off w...
cjperone100
Dec 28, 2017Aspirant
When this happened tp me. I changed pixel to static ip address rather than dhcp. it stopped the crashes.
not the most ideal solution but maybe it will help ubtil a true fix.
- rhester72Dec 28, 2017Virtuoso
cjperone100 wrote:When this happened tp me. I changed pixel to static ip address rather than dhcp. it stopped the crashes.
Not sure it would...my Orbi is in bridged mode and thus doesn't answer DHCP requests.
A bit more evidence that it doesn't seem to be DHCP-related...if I put the OnHub on a switch off my (not Orbi) router, even though the broadcast -reaches- Orbi, it doesn't crash...which strongly suggests that the traffic causing the crash is unicast.
- rhester72Dec 29, 2017Virtuoso
I stand corrected - just had another crash with OnHub on a switch in parallel with Orbi. You may very well be right that it does indeed involve DHCP broadcast.
Just switched to static on my Pixel 2 XL, will let this bake for a couple of days.
- logdumpDec 30, 2017Aspirant
Out of curiosity, is there IPv6 on your network ?
