turnerm05
Dec 09, 2017Luminary
Android 8 Crashes Orbi
I've been tracking down an issue where my Orbi just suddenly drops wifi and reboots. I've isolated it to be associated with an Android device running 8.0 or higher. And I've proven it turning off w...
RobbieCrash
Jan 10, 2018Guide
My additional $0.02 while using a Pixel 2 on the December patch:
1. When the satellite is online every time my phone connects, or every time it wakes from sleep, the Orbi router reboots. The satellite stays active and responsive. However, I'm always connected to the router, not the satellite.
2. When the satellite is offline, rather than rebooting the router, the wifi just drops. Each time this happens the following shows up in dmesg:
[wifi1] FWLOG: [133669581] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0xad79, 0x0 ) [wifi1] FWLOG: [133669581] WAL_DBGID_SECURITY_ENCR_EN ( ) [wifi1] FWLOG: [133669581] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x43eb8c ) missing case for op class 83 in ieee80211_mbo_operating_class_to_chan missing case for op class 84 in ieee80211_mbo_operating_class_to_chan missing case for op class 116 in ieee80211_mbo_operating_class_to_chan missing case for op class 117 in ieee80211_mbo_operating_class_to_chan missing case for op class 118 in ieee80211_mbo_operating_class_to_chan missing case for op class 119 in ieee80211_mbo_operating_class_to_chan missing case for op class 120 in ieee80211_mbo_operating_class_to_chan missing case for op class 121 in ieee80211_mbo_operating_class_to_chan missing case for op class 122 in ieee80211_mbo_operating_class_to_chan missing case for op class 123 in ieee80211_mbo_operating_class_to_chan missing case for op class 124 in ieee80211_mbo_operating_class_to_chan missing case for op class 125 in ieee80211_mbo_operating_class_to_chan missing case for op class 126 in ieee80211_mbo_operating_class_to_chan missing case for op class 127 in ieee80211_mbo_operating_class_to_chan missing case for op class 128 in ieee80211_mbo_operating_class_to_chan missing case for op class 130 in ieee80211_mbo_operating_class_to_chan Disabled for Offload Architecture [wifi1] FWLOG: [133671920] RATE: ChainMask 3, peer_mac ad:79, phymode 10, ni_flags 0x0621b006, vht_mcs_set 0xfffa, ht_mcs_set 0xffff, legacy_rate_set 0x0ff0 [wifi1] FWLOG: [133671920] RTT_REPORT ( 0x2804, 0x3, 0x479, 0x0, 0x9 ) [wifi1] FWLOG: [133672064] MGMT_TXRX_MU_GID_MGMT ( 0xaf, 0x2, 0x0, 0xfffe, 0x0 ) [wifi1] FWLOG: [133672064] MGMT_TXRX_MU_GID_MGMT ( 0xb3, 0x0, 0x0, 0x0, 0x0 ) [wifi1] FWLOG: [133672064] MGMT_TXRX_MU_GID_MGMT ( 0xadd, 0x2, 0x0 ) [wifi1] FWLOG: [133672427] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0xad79, 0x0 ) [wifi1] FWLOG: [133672427] WAL_DBGID_SECURITY_ENCR_EN ( ) [wifi1] FWLOG: [133672427] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x43eb8c ) Switching to Tx Mode-1 Threshold 0 [wifi1] FWLOG: [133674728] WAL_DBGID_TX_BA_SETUP ( 0x43eb8c, 0xad790006, 0x2, 0x40, 0x1 ) [wifi1] FWLOG: [133674739] RATE: ChainMask 3, peer_mac ad:79, phymode 10, ni_flags 0x0621b006, vht_mcs_set 0xfffa, ht_mcs_set 0xffff, legacy_rate_set 0x0ff0
guzzijason
Jan 11, 2018Apprentice
Interesting. I'm curious to know if you have fast roaming on or off. And, does this log behavior change at all if you toggle that setting. I ask, because I'm pretty sure that "MBO" has to do with roaming behavior.
RobbieCrash wrote:My additional $0.02 while using a Pixel 2 on the December patch:
- RobbieCrashJan 11, 2018Guide
All three advanced options are on, disabling them has no impact on the messages logged in dmesg, nor does it seem to impact stability at all.
- sleepr88Jan 11, 2018Apprentice
Since I can't use my Pixel 2 XL or my Nexus 6P on wifi with the Orbi(obviously with current issue) I started using my old Note 3 to play games on. Well it also makes the Orbi system REBOOT every time it wakes up! I wish Netgear would just refund me for this junk system because it doesn't seem like they will ever fix it?
Any suggestions anybody?
- mad2Jan 11, 2018Guide
I upgraded my new RBK50 system to 2.1.1.16 and had rebooting issues. I have a lot of Android phones and tablets in the house. I reverted back to 2.0.0.74 and continued to have issues. The beta seemed better, but still has problems - it seemed like a few of the re-boots became temporary WiFi drops. I read on one of the threads that someone reverted their system back to 1.11.0.20 and didn't have rebooting issues. I had tried 1.12.0.18 and had issues, so I went back another version and tried 1.11.0.20 (before connecting to the outside world I disabled auto updates). Both the router and satellite have been up over 24 hours with no reboots, and no one has complained of losing WIFI. Obviously it isn't a good fix, has security issues, and it may very well crash, but it seems to be the most stable if you don't mind living with the other limitations / bugs. My system sits behind another router so it isn't exposed directly to the internet. I assume that there must have been a kernel and / or driver update after that version. Just wanted to share in case it is of value to someone else.
