turnerm05
Dec 09, 2017Luminary
Android 8 Crashes Orbi
I've been tracking down an issue where my Orbi just suddenly drops wifi and reboots. I've isolated it to be associated with an Android device running 8.0 or higher. And I've proven it turning off w...
Hydro130
Jan 17, 2018Luminary
Tpars wrote:I have removed my 4 chromecast devices, updated to the new firmware 2.1.2.18. I still get reboots. If I log onto my RBR50 and RBS50 (Pixel XL) within 1 minute the router reboots. NOTHING is getting fixed here.
Firmware 2.1.2.18 does not claim to address the Chromecast issue.
That issue appears to be on Google's end to fix, and Google is supposedly releasing an update tomorrow (1/18) for it.
lprzybylski
Jan 17, 2018Guide
Let's all just keep in mind, that if these Google Chromecast issues are the cause of our reboots, its not all Google's fault. While they have bugs in there Chromcast infrastucture, a device on your LAN should not be able to overwhelm or reboot your router. 100,000 packets isn't even that much compared to a real DoS attack, which Netgear claims they have protections for. Other routers have protections (like rate control) that are stopping this from becoming an issue on their network.
Netgear needs to address this issue from their end. Otherwise the next bug (from any company) will just overwhelm the router all over again.
- lprzybylskiJan 17, 2018Guide
I'm removed all my Chromecast devices (Google Home and Chromecast dongles) from my network. I've signed up for the Google Play Services beta (now running 11.9.73) on both Galaxy S7 edge phones. And removed the Google Home app from my phone.
With this config since, I haven't had a reboot and my phone would always reboot the network in the morning when I woke up (not this morning though). Its been a short amount of time, but I wanted to share it with all of you anyway.
