airwolf666
Apr 01, 2019Aspirant
Android app doesn't connect to my orbi router
I am having an issue logging into my orbi android app in that i insert the password which works and then it takes me to the next page and then before i can choose what to do, the app takes me back to...
Apr 01, 2019Guru - Experienced User
Remove the app, reboot the device, re-install the app and try again? v2.3.1 is most current on Android I believe.
airwolf666
Cleared the cache, cleared the app data, uninstalled the app. Shutdown the phone and reinstalled the app and does the samething and still is the same version. If this newer version just came out it can take a couple of weeks to get pushed out on google play.
- FURRYe38Apr 01, 2019Guru - Experienced User
It's appeared on my Galaxy Tab S2...released on 3/28.
- bulldog4791Apr 24, 2019Aspirant
I have the exact same issue. I did the uninstall and reinstall of the app and restarted my Samsung Galaxy s10+
- FURRYe38Apr 24, 2019Guru - Experienced User
Please post here about this:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
