YP
Nov 22, 2018Aspirant
Android connectivity issue on Pixel
I am facing strange issue with my Orbi wifi connection on Google Pixel 3 XL. Pixel connects to wifi and i can browse with chrome but apps are not connecting to internet. When I connecct mobile data i...
Nov 23, 2018Guru - Experienced User
What FW is currently loaded?
Using any custome DNS on the Orbi router or letting it detect DNS from ISP?
Is this the only device that exhibits this problem?
YP wrote:
I am facing strange issue with my Orbi wifi connection on Google Pixel 3 XL. Pixel connects to wifi and i can browse with chrome but apps are not connecting to internet. When I connecct mobile data it is working fine no issue. I tried connecting to several other wifi and it works fine no issue.
any help in solving this mystery is appreciated.
- YPNov 23, 2018AspirantMy RBK50 is on V2.2.1.210. I have Verizon on the connected to my orbi. There is no modem in between.
I changed dns to Google dns yesterday and still same issue.
It is happening only on pixel 3 xl.- FURRYe38Nov 23, 2018Guru - Experienced User
You might contact Google about this and let them know what your seeing and that this is the only device giving a problem with the Orbi.
- YPNov 23, 2018AspirantGoogle support asked to factory reset and try out. I did 4 time factory reset. Now they are saying it is Netgear issue. So disappointing to see this from Google.
