chris_at
Mar 05, 2019Tutor
Android Device can't connect to network ressources although stays connected to Wifi
Device:
Sony Z2 Tablet running Android 6.0.1 (last Update from Sony)
ORBI50 AC3000 with latest firmware (V2.2.1.210)
Never had any issues with a Netgear Nighthawc AC1900 R7000 running on DD-WRT...
Chuck_M
Mar 05, 2019Mentor
chris_at wrote:
Device:
That's not the latest firmware. Download and install v.32 to see if problem persists.
chris_at
Mar 05, 2019Tutor
Where do I get this firmware?
The update function says 2.2.1.210 is the latest and also on the product support page there is only this version available.
I then found a page for 2.3.0.32 saying
"If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212. After updating the firmware v2.2.1.212, your Orbi router will reboot, and then you can update to v2.3.0.32. "
So I need to get 2.2.1.212 first ... is there actually a support page that lists all available versions and why is 2.2.1.210 listed as current if newer versions exist? Or are these version still beta / unstable?
- Chuck_MMar 05, 2019Mentor
If you read the forum thread titles, you will find exactly what you are looking for.
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
Here is intermediate firmware link:
https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
