Vinterbird
Dec 17, 2016Star
Android devices keep getting thrown off the Orbi WiFi
(This was also an issue before the latest firmware) Our Android devices (tablets and phones) keep experincing the same issue. They are all sporadically thrown off WiFi and re-connected again a fe...
TomMac
Dec 17, 2016Guru
Wonder if the two are related?
https://community.netgear.com/t5/Orbi/iOS-devices/td-p/1189718
Vinterbird
Dec 17, 2016Star
Looking at the thread at a glance, I don't think so. I've never had issues with the iOS devices in the house and this was before the latest firmware hit, it's also present on the latest firmware. But the root of the issue might be the same.
- rseijenDec 17, 2016Guide
I have the same problem with two android phones. My IOS products work fine but the android ones keep ketting disconnected en reconnected. Very very annoying. I am honestly thinking about returning this product because its faulty in my opinion.
- VandergraffDec 18, 2016Apprentice
Yes same issue here.
Android client (Samsung Galaxy) disconnects and then reconnects - it reconnects quickly but is frustrating
- DarrenMDec 19, 2016Sr. NETGEAR Moderator
Hello everyone
First thing I would try to do is to disable beamforming and Mu Mimo see if that is causing the issue. The setting is located in Advanced-Advanced Setup- Wireless setting and should be 2 check boxes at the bottom. The other thing I can think of is the wifi radio may be bouncing back and forth between the satellite and the main router causing the disconnects you could try to position the satellite a little further away if possible.
DarrenM
