Vinterbird
Dec 17, 2016Star
Android devices keep getting thrown off the Orbi WiFi
(This was also an issue before the latest firmware) Our Android devices (tablets and phones) keep experincing the same issue. They are all sporadically thrown off WiFi and re-connected again a fe...
rseijen
Jan 11, 2017Guide
No luck with that option. Just noticed that my chromecast does the same thing. Again on the sattelite.
Retired_Member
Jan 15, 2017Bumping this as I finally had to turn off wifi on my s7 edge because it was killing the battery constantly dropping like that. I emailed netgear support as it's been a while now with no resolution to my case, to get with it and get this issue fixed.
- Streak2Jan 15, 2017Master
My S7 Edge and Galaxy Tab S2 still have no problem.
I know others with Android devices who also do not have an issue.
It appears to be a problem in only certain instances.
I also contacted Netgear about this offering engineering to see what's different about my installation to try and see how yours can be fixed.
