Vinterbird
Dec 17, 2016Star
Android devices keep getting thrown off the Orbi WiFi
(This was also an issue before the latest firmware) Our Android devices (tablets and phones) keep experincing the same issue. They are all sporadically thrown off WiFi and re-connected again a fe...
bgstewar
Mar 15, 2017Guide
Any progress? Happens constantly now and am ready to return if there's no fix coming. Others with S7's reporting same problems.
- Streak2Mar 15, 2017Master
I have an S7 Edge and a Galaxy Tab S2.
No problems with either on two different Orbi systems.
The S7 now runs Android 7 but had no problems with Android 6 either.
For now I have beam forming and mimo set off, but worked just as well with them set on.
I also have 2.4ghz running at full power, some suggested reducing this could help with the issue.
So it seems that it's not a problem with every installation but a could be a combination of things in certain installations that cause the problem.
- Retired_MemberMar 15, 2017
Mine had issues with the S7 Edge and LG V20, and iPhones. After many things I gave up, and returned it.
- Random12Mar 15, 2017Apprentice
Has anybody checked if this issue is resolved with the new firmware released yesterday?
