AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
Retired_Member
Dec 05, 2017System- RBR50 and 2 RBS50's
Process followed to upgrade:
1) Factory reset system
2) Upgraded firmware on Sats
3) Upgrade firmware on Router
4) Factory Reset System
5) Manually reconfigured all rules and settings
Attached Devices shows no devices or Sats connected, however 62 devices are connected as are both Sats and devices connected to the Sats are working.
- spinkickDec 05, 2017Apprentice
Same, not showing any connected devices, nor do I see any options for ethernet backhaul, are we supposed to just connect it and it will detect it?
- thebadpeteDec 05, 2017Guide
I manually installed the latest firmware yesterday night, I have been noticing that my wifi speedtest throughput is dropped.
Specifically, my broadband provider has 20mb download speed. (Yes, very slow, but I swear not going to Comcast) If I did speedtest from Orbi admin menu directly, I can get close to the max 20mb download speed. However if I do it from my laptop or my phone, I only get 12mb. Even if I stand right next to my Orbi router it is the same.
Does anyone see similar throughput dropping issue? - mkenny28Dec 05, 2017Apprentice
Same issue here. No attached devices showing but everything is working.
- AmitRDec 05, 2017NETGEAR Employee Retired
Yes. Once you connect two Orbi using Ethernet, it will auto detect and switch over. May take a few mins.
- MrX911Dec 05, 2017Apprentice
Any early perfomance reports on 2.1 from indiviudals that have been suffering dropouts?
- woolyninjaDec 06, 2017Aspirant
I had the same issue with no devices being shown so I unplugged the main and satellite... plugged in the main, waited a minute then plugged in the satellite. Devices now showing up as expected
- mastervisa30Dec 07, 2017Luminary
Now i got the same problem,no devices being shown.
I Have tried unplugged the main and satellites and plugged in the main waited a minute then plugged in the satellites.
No devices being shown on my app,web browser.
This has never happend before this new firmware realese.
- Retired_MemberDec 07, 2017
mastervisa30 wrote:Now i got the same problem,no devices being shown.
Reported here: https://community.netgear.com/t5/Orbi/Defect-OrbiOS-2-1-1-12-Attached-Devices-Widget-amp-Page/m-p/1448040#M16917
