AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
JC_Wifi
Dec 05, 2017Aspirant
Updated firmware to V2.1.1.12 and connected satellite via wired backhaul. Now devices connected to Satellite are incorrectly shown with a connection type of WIRED.
- MrX911Dec 06, 2017Apprentice
Is it necessary to do a factory reset before the upgrade? I followed the online intstructions from Netgear and there was no mention of this so I proceeded without it. Less than 24 hours but no drops yet and I’d been suffering a lot on the last firmware. Might get to keep the Orbi after all. Fingers crossed.
- Retired_MemberDec 06, 2017
MrX911 wrote:Is it necessary to do a factory reset before the upgrade? I followed the online intstructions from Netgear and there was no mention of this so I proceeded without it. Less than 24 hours but no drops yet and I’d been suffering a lot on the last firmware. Might get to keep the Orbi after all. Fingers crossed.
You just never know. I've had periods of days and weeks where it was rock solid and then be terrilbe. Reboot the router a few times and use it before declaring success.
- tofloDec 07, 2017Tutor
I did not do a factory reset, but everything seems to work fine anyway :-)
- TgtermDec 07, 2017Guide
Updated two sats and the router...no issues. All connected devices appearing as expected.
Now, just hoping for a little more stability in my life...and my wifi. Hopefully, the vanishing wifi issue vanishes.
