AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
vlix
Dec 06, 2017Initiate
If i use the Ethernet Backhaul, what happens with the Wireless Backhaul?
Will it be disabled? Can it be used by Client Devices to connect?
- plemansDec 06, 2017Guru - Experienced User
I'm not showing that anything happens to it. I was hoping it'd be freed up for the 3rd radio to be used. I show through inssider though that its still there as a hidden network. I don't see any options to use it. That's to bad as it was one of the major benefits of ethernet backhaul. Here's to hoping a future upgrade allows us to use it. Or at least allow us to disable the wireless backhaul so I can use a different device in the 149-165 range without having to worry about any interference.
