AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
Hydro130
Dec 06, 2017Luminary
I have just one satellite, and I'll contunue to use wireless backhaul (no ethernet).
In the Attached Devices screen, I see a new entry for the status/quality of my satellite's wireless connection -- mine says "Good" (in green-colored font)
Beyond "Good", can you please tell us what the other possible values for this field are? (i.e. Bad, Poor, Excellent, etc)
Is "Good" the best / most desirable entry that I can have here?
I'm curious if there's an "Excellent" or (some similar descriptor that's higher that "Good") that I should perhaps try to shoot for.
Thanks!
SharkSight
Dec 06, 2017Aspirant
I have the same question as Hydro130... mine says good also... wondering what other indicators may appear here.
