AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
Davapersson
Dec 06, 2017Guide
Great :)
A few questions
1. If I have a satellite connected with Ethernet Backhaul, can the satellite still use wifi backhaul to another satellite using Daisy chain?
2. Does the Ethernet Backhaul satellite use all its antenna bandwith to the ”ordinari wifi” because it has no longer use for the 5G backhaul anymore?
3. I assume the router can connect to one satellite with ethernet backhaul and another satellite with wifi backhaul?
Sincerely
David
- JMU1998Dec 06, 2017Luminary
Does this Firmware include the fix for the hack that came with the .76 patch? Or we have to apply patch after upgrading Firmware?
- Hydro130Dec 06, 2017Luminary
JMU1998 wrote:Does this Firmware include the fix for the hack that came with the .76 patch? Or we have to apply patch after upgrading Firmware?
Answer in release notes:
https://kb.netgear.com/000052784/RBR50-RBS50-Firmware-Version-2-1-1-12
- coolvaDec 06, 2017Aspirant
Anyone else experiencing very slow ethernet backhaul connections? I can only get ~50mbps when connected to the satellite...
