AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
lewgar
Dec 08, 2017Initiate
Upgraded the RBK50 to 2.1.1.12 as per support advice, multiple disconnects on WIfi, had the system a week. Now getting download speeds no higer than 30MB, service is 200MB. Tested against modem direct, getting 200MB down. This might stablize the wifi, we will see, but not at the expense of the download speed. Seems like others are seeing this same issue. I did reset the router and reconfigured from scratch, shouldn't ahve to do that, no change. How to fix this?
BarryTreg
Dec 08, 2017Apprentice
Re Ethernet Backhaul
I wired up my one satellite for ethernet backhaul. It shone blue, but not sign of it in the attached devices page
Powered everything off and on again, but no difference.
Then just powered off satellite and it showed up again in attached devices, but as disconnected.
Are there any other settings to be aware of? (Does daisy chain need to be on?)
thanks
