AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
mastervisa30
Dec 09, 2017Luminary
that's the same problem here, going back to 76 beta later today that worked perfectly for me just wanted to test the last firmware a little. but a bit frustrating and not seeing all devices and everyone is connected to router,there is i Big bug here.
Spadde
Dec 10, 2017Guide
Our devices are connected to Router and Satellite 1 depending the location in the house. So just saying that this firmware does not block this entirely because it's working correcly in our house. Only downside I noticed is that most of the devices are shown as Unknown but sometimes they have their names on the list. But main point is that network is fast enough, it's rock solid (and both router and satellite connection works as should). So this kind of experience here about this firmware.
- aazDec 10, 2017Virtuoso
Spadde, how did you do the upgrade? Anything special? On previous firmware everything was working correctly for me, now all of a sudden, it's not. Are you sure that you can see devices in the device list that clearly say attached to satellite instead of router?
- SpaddeDec 10, 2017Guide
Hi aaz, nothing special. I first updated satellite and then router. After I just restarted the devices and that's it.
I do rely what the Orbi android sotware says about where these devices are connected. Because it clearly states that are these devices connected to router or satellite 1 when you press the info button from the device list for specific device. And example with my phone this connection changes depending which part of the house I'm located.
- Greyhawk68Dec 11, 2017Star
Well I took the plunge and upgraded the firmware, hoping it would solve things, and it only made everything worse.
When Orbi worked great for 10 months, I would get 120 Mbps out in my man cave. Since 2.0, it disconnected so frequently as to become untrustworthy, dying in the middle of streaming or gaming all the time. Now when I updated today to 2.1, my throughput has dropped to less than 1 Mbps in the same location. I've factory reset, I've resynced, I've restarted everything multiple times to no avail.
I've invested $650 dollars in this system and I'm going to have to eat it now and buy something else. This will probably swear me off of Netgear for good unfortunately.
For those of you for whom it's working, I really hope it keeps it up. It was fantastic for me when it did. If you want some satellites or an extra router for cheap, feel free to message me.
-Grey
