AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
CattleDog
Dec 19, 2017Aspirant
I applied 2.1.1.16 and it appears to have fixed the issues I was having (its been about 8 hours so far).
- netgearguyDec 19, 2017ApprenticeDoes it fix the intermittent network drops/loss of connectivity?
- webminsterDec 19, 2017Luminary
Doesn't appear to fix the display of attached devices as advertised... it showed up for 3 hours after the update, now is consistently empty on my satellite. Am certain there are devices connected to the satellite.
- CattleDogDec 19, 2017Aspirant
netgearguy wrote:
Does it fix the intermittent network drops/loss of connectivity?It has for me. Stable all day and great download speeds. I have 300m/b service and was able to hit 297m/b over wirelss on my Mac.
- spinkickDec 19, 2017Apprentice
Those that have speed back, did you have the speed issue where it would go away after a while? Did you guys do a hard factory reset with your update?
- kmichalecDec 19, 2017Apprentice
CattleDog wrote:I applied 2.1.1.16 and it appears to have fixed the issues I was having (its been about 8 hours so far).
Which issues were you having exactly, and what FW version did you upgrade from?
Loss of connectivity about once every hour or two. Would typically last 5 to 10 minutes. I have two satellites. One disappeared (no longer seen as a connected satellite). The other seemed ok, but suffered the same drop out issue (probably coming from the router).
I was fine and stable on 2.0.0.74 on all 3 devices (RBR50 and 2 RBS50). I manually applied the 2.1.1.12 update to the router and it all went to hell. The satellites would never take .12 manually. After a few days, I rolled the router back to 2.0.0.74, but the issues remained.
I am now on 2.1.1.16 on all 3 devices, and everything is working as expected (I had to manually re-add the one satellite).
- dpaugroDec 19, 2017Tutor
Upgraded router to v2.1.1.16 as soon as I arrived home. Already observed more stability in the network with respect to handling both satellites. Will apprise. Thanks, Netgear!
