AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
CattleDog
Dec 19, 2017Aspirant
I applied 2.1.1.16 and it appears to have fixed the issues I was having (its been about 8 hours so far).
netgearguy
Dec 19, 2017Apprentice
Does it fix the intermittent network drops/loss of connectivity?
- webminsterDec 19, 2017Luminary
Doesn't appear to fix the display of attached devices as advertised... it showed up for 3 hours after the update, now is consistently empty on my satellite. Am certain there are devices connected to the satellite.
- CattleDogDec 19, 2017Aspirant
netgearguy wrote:
Does it fix the intermittent network drops/loss of connectivity?It has for me. Stable all day and great download speeds. I have 300m/b service and was able to hit 297m/b over wirelss on my Mac.
- spinkickDec 19, 2017Apprentice
Those that have speed back, did you have the speed issue where it would go away after a while? Did you guys do a hard factory reset with your update?
