AmitR
Dec 04, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here: https://www.netgear.com/support/product/RBK50.aspx#download https://www.netgear.com/support/product/RBK40.asp...
tagteam
Jan 07, 2018Virtuoso
Not sure whether or not it will be of much utility to you, but a Netgear support article on the subject is at the link below.
Bing-Stroller
Jan 07, 2018Luminary
I had similar problems with crashing and random reboots when I tried the ethernet backhaul (between 2 satellites) on a reasonably stable setup.
Appreciate the diagrams - thanks.
But, with no clear guidance on how to get to that stage it's all guess work.
i.e sync everything and then connect or switch on in a particular sequence after connecting.
It's all trial and in my case - error/crash.
- tagteamJan 07, 2018Virtuoso
Bing-Stroller wrote:
...But, with no clear guidance on how to get to that stage it's all guess work....It's unfortunate that even the user manual, which was just updated last month, doesn't provide more specificity.
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
