Bullyterrier
Nov 27, 2018Star
Another .210 fail today
After running well for a while today the router decided to block a subset of my devices from the internet. All had access to the router but no further. All wired, some via a tp link dumb switch, some ...
Nov 27, 2018Guru - Experienced User
Possible that this bug maybe only on your system since nobody else has reported it. Could be something on your system that could be causing what your experiencing. Hard say.
After setting up the router and you have it fully working again, do a save configuration to file and keep this file for safe keeping next time you have to do a factory reset. This will help avoid the long setup after a reset.
