Nailem
Dec 23, 2018Aspirant
Another Orbi dropping connection thread
Hello all, I've had my Orbi RBK50 and RBS50 set up for roughly 6 months. When I first got it I was having a lot of dropped connection issues. I tried several things from the community, channel, unmark...
Nailem
I do have my Arlo base unit plugged into the satellite. I'll try unplugging and testing.
I do not have a reserved IP for the sat. I'll Google how make that change. What's weird is it for several months with no issues but now I'm back to my original issue. I have always had my Arlo plugged into it.
Thanks
Thanks
ekhalil
Dec 23, 2018Master
Thanks
Please test to disconnect the wired devices and see if this will bring any change.
As I mentioend the issue can be with your IP network.
- Has there recently been an change in your ISP router or Modem?
- If you have an ISP router, is it bridged?
- Do you have Orbi in Router Mode?
- Do you have an ISP
- What IP address is assigned to the Satellite when the issue happens?
- Please set a reserved address for the Satellite. You can do this by going to >> ADVANCED >> Setup >> LAN Setup >> and click on ADD on the bottom of the page.
