BigRune
Feb 25, 2020Apprentice
Another RBR50 Dropping Internet Connection
OK, so now I just about had it with this Netgear setup I bought. Seven week old setup of RBR50 and a wired RBS50. fwV2.3.5.30 on both devices.Router Connected to a CTS HES 3106 Fibre converter s...
- Feb 26, 2020
Today I feel total relief. I returned the RBK50, got a total refund and installed my old ugly, no-app, rock-solid AC3200 router.
Could not imagine a product that flawed would still be in the shelves. Good luck you all with future firmware uppdates and endless discussions what equipment this malfunctioning piece of garbage is,connected to :smileylol:.
ekhalil
Mar 17, 2020Master
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following commands:
- root@RBR50:/# config get wan_lease — Should give you --> 86400 as default
- root@RBR50:/# config set wan_lease=1200
- root@RBR50:/# config commit
RockTheGlobe
Jun 29, 2020Apprentice
Been having a similar issue with my new RBK753 and have been trying to follow the directions here, but whenever I go to the Debug page, there's no option to enable Telnet. Has the ability been removed?
- FURRYe38Jun 29, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum for your model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Telent doesn't seem to be a feature on Orbi AX.
Thank you.
RockTheGlobe wrote:Been having a similar issue with my new RBK753 and have been trying to follow the directions here, but whenever I go to the Debug page, there's no option to enable Telnet. Has the ability been removed?
