bolingde
Oct 30, 2018Guide
Another smart plug question
I have a smart plug and like most it only works at 2 4G. Yes it seems like it should work with the 2.4 channel on the orbi but it doesn't, because the Smart Life app states "it will only work on 2.4g ...
bolingde
Oct 31, 2018Guide
Thanks but that sounds like lot of configuration for something that may/may not work for 5 minutes and may break something else work. BTW, FW is up to date and I changed the channel to 1 and neither worked. It really seems like an underlying problem with mesh networks (at least orbi). Everyone is using smart home devices and if netgear can't come out with a simplified solution I think it will be the death nail for the orbi.
Oct 31, 2018Guru - Experienced User
I would try the suggestions. Others have been able to get some working.
Not all smart devices are compatible with MESH systems as well. You should contact the Mfr of the device to ask about this.
Good Luck.
