ThamJK
Jun 26, 2020Aspirant
Any LAN port devices support to Orbi RBK53?
Hello Guys, I just got my RBK53 today and both satellites I have put on second floor, but there’s no extra satellites for me to connect LAN to my CCTV DVR (my main router is far from my DVR). My quest...
- Jun 27, 2020Problem Solved:
I pair my asus router in bridge mode with my satellite
Jun 26, 2020Guru - Experienced User
potentially you could get a different manufacturer's repeater to connect. But I'd only use it as a hardwired connection for the camera setup. It could cause some interference as usually the repeaters use the same wireless channel the device they're connecting to is using. And the other repeater isn't controlled by the orbi router.
- ThamJKJun 26, 2020AspirantHi, thank you for your replied.
I have other manufactured access point device, what my idea is I make the access point device is connected to the internet and then it connect to my DVR by wired. But when I use the access point device to search for network, it couldn’t find my Orbi network.
