ThamJK
Jun 26, 2020Aspirant
Any LAN port devices support to Orbi RBK53?
Hello Guys, I just got my RBK53 today and both satellites I have put on second floor, but there’s no extra satellites for me to connect LAN to my CCTV DVR (my main router is far from my DVR). My quest...
- Jun 27, 2020Problem Solved:
I pair my asus router in bridge mode with my satellite
Mikey94025
Jun 26, 2020Hero
ThamJK wrote:
Hello Guys, I just got my RBK53 today and both satellites I have put on second floor, but there’s no extra satellites for me to connect LAN to my CCTV DVR (my main router is far from my DVR). My question is can I use my old tplink/Asus repeater device and connect to Orbi network and transmission network by LAN to my DVR? Or any low cost product that I can get the wireless from Orbi and connect to my dvr thru LAN cable?
Your old router can likely also be used as a wireless bridge to your new Orbi network and let you plugin via ethernet for your DVR. For Asus they seem to call this "media bridge" mode. For example, here's the Netgear instructions to do it fo one of their routers: https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
> But when I use the access point device to search for network, it couldn’t find my Orbi network.
If you already tried the wireless bridge mode on your okd router but it couldn't connect to your Orbi network, you can try modifying the Orbi wireless settings like Beamforming, MIMO, Fast Roaming, 20/40Mhz Coexistence and see if that makes it more compatible.
ThamJK
Thank you for reply. I will try this😚
