Damien2818
Feb 09, 2020Follower
Any one having problems turning on and off guest WiFi?
Since Jan 31 last update I can not turn on or off guest WiFi I have my Orbi as a bridge system with an existing System so I put my kids on the guest WiFi so I can turn on and off WiFi as needed but s...
Feb 10, 2020Guru - Experienced User
Damien2818 wrote:Since Jan 31 last update I can not turn on or off guest WiFi I have my Orbi as a bridge system with an existing System so I put my kids on the guest WiFi so I can turn on and off WiFi as needed but since update I can no longer do so anyone have the same problems or know of a fix for it. Everything else is working fine
