astrojohn
Apr 01, 2019Tutor
Anyone else notice this
I am nearly positive this is NOT an Orbi issue but I thought I'd see if anyone else has noticed something similar. I have my Orbi connected behind my Uverse router (WiFi disabled, used only as a mode...
- Apr 01, 2019
Sounds like it. Hopefully they will listen to you. Just explain to them what all you have done.
Have them look at the signal and there logs. Have a tech come out if thats possible.
Good Luck.
Chuck_M
Apr 01, 2019Mentor
Can you do that same test without the Orbi in the equation? (I didnt see that in your post, if it is there I apologize)
Others have reported Google issues.
