astrojohn
Apr 01, 2019Tutor
Anyone else notice this
I am nearly positive this is NOT an Orbi issue but I thought I'd see if anyone else has noticed something similar. I have my Orbi connected behind my Uverse router (WiFi disabled, used only as a mode...
- Apr 01, 2019
Sounds like it. Hopefully they will listen to you. Just explain to them what all you have done.
Have them look at the signal and there logs. Have a tech come out if thats possible.
Good Luck.
Chuck_M
Apr 01, 2019Mentor
Can you do that same test without the Orbi in the equation? (I didnt see that in your post, if it is there I apologize)
Others have reported Google issues.
astrojohn
Apr 01, 2019Tutor
Re-ran with two PCs hardwaired into the Uverse modem - about the same results so the Orbi is out of the picture.
You may be right about a Google issue but I'm not sure how they could inhibit downloads from another source so I setup two different speed test websites: dslreports and speedtest.net. Same results so Google is in the clear this time and ATT is the culprit. But now I have to actually talk to them...ugh.
John
- FURRYe38Apr 01, 2019Guru - Experienced User
Good Luck.
- astrojohnApr 01, 2019Tutor
Been thinking about Spectrum Internet anyway, much higher rates, lower per MB cost but never liked their predesccor (TimeWarner). We'll see...thanks
