astrojohn's avatar
Apr 01, 2019
Anyone else notice this
I am nearly positive this is NOT an Orbi issue but I thought I'd see if anyone else has noticed something similar. I have my Orbi connected behind my Uverse router (WiFi disabled, used only as a mode...
  • FURRYe38's avatar
    Sounds like it. Hopefully they will listen to you. Just explain to them what all you have done.
    Have them look at the signal and there logs. Have a tech come out if thats possible.
    Good Luck.
