alg42
Apr 04, 2017Guide
Anyone have sucess setting up Chromecast on ORBI in guest mode
ORBI system in router mode. Has anyone gotten a chromecast to work on the guest network without selecting "Allow guests to see each other and access my local network"? The system is set up in...
rhester72
Apr 04, 2017Virtuoso
You can't have your cake and eat it, too.
Chromecast is by definition peer-to-peer...if the peers can't talk, nothing useful is going to happen.
Rodney
alg42
Apr 10, 2017Guide
Rodney,
I am starting to see the wisdom behind your response.
Orbi system is really nice experience from the clientele side of things (appears as one network, good handoffs, etc) but the backend is not super configurable.
Planning on going to AP mode and putting a wired router in to manage traffic and security. Hopefully this will give the best of both worlds.
- rhester72Apr 10, 2017Virtuoso
Good plan in general, but be aware that as of the time of this writing, guest mode isolation isn't working properly in AP mode (it results in guests having no connectivity at all). That's been the case for a couple of past releases, hopefully it will get fixed in the near-ish future.
Rodney
- CarneaMay 25, 2017Tutor
Hello Alg42 !
Same problem here. It's weird that Chromecast won't run in Orbi's guest mode : Airplay over Apple TV and Microsoft Wireless Display Adapter (miracast) do work with the Orbi in guest mode. Very disappointing from Orbi (and Chromecast).
Did you manage to find a solution ? I assume we wanted to do the same kind of thing as you : have a simple way for the visitors of our conference room to cast to our big TV screen.
I tried to connect the Chromecast with the "private" wifi and then to use Chromecast's guest access with no luck...
- alg42May 25, 2017Guide
I installed a Ubiquiti edgerouter to manage all of my traffic and routing and set the Orbi into AP mode. I feel like its the best of both worlds. For the most part the wireless subnet (Orbi) is wide open with guest being able to see each other. The wired network is on a seperate subnet with only very specific traffic allowed from wireless to wired (all managed through firewall rules).
The chromecast users are happy. I am happy. Look into the Erlite-3 it's a suprisingly powerful box that is super affordable. In my case I went with a pre-owned ER-8 which is a bit more powerful.
