PSYOP-ANALYTICA
Sep 06, 2019Aspirant
Anyone know what the wifi router model is
Anyone know what this wifi router model is .....
- Sep 08, 2019
This is the RBS50Y, the outdoor Orbi Satellite.
ekhalil
Sep 08, 2019Master
- michaelkenwardSep 09, 2019Guru - Experienced User
https://www.netgear.com/orbi/rbs50y.aspx
Indeed. And mine says so on the label on the back. That may also reveal if this is the newer V2 version.
There is support for this device, including manuals, at the end of this link:
>>> Orbi RBS50Y | WiFi System | NETGEAR Support<<<
- PSYOP-ANALYTICASep 09, 2019Aspirant
Thank you for you update
ekhalil wrote:This is the RBS50Y, the outdoor Orbi Satellite.
Thank you for your answer.
