scttq
Jan 17, 2019Guide
Anyone Successfully Using Mixed Wireless and Wired Backhaul?
Hi,
I've been using an AC3000 system (w/ 2 satellites) for about 1.5 years, been through some ugly times with constant disconnects but the platform really seems to have improved over the last y...
- Jan 23, 2019
It's been 4 days now and all is still good.
To summarize (based on my observations):
- I added an AV rack, rack switch and wired backhaul to my basement, previously was on wireless with everything working fine
- Day after this new setup, entire network went down
- Two seperate issues were discovered:
- Four Sonos components were hard wired to the switch, the components don't automatically disable their wifi connection and apparently introduced a network loop
- My Sony Android TV when connected over ethernet tends to cause a type of network storm over UDP because of a bug in the Chromecast feature. This was corrected for the wifi adapter but not the ethernet adapter.
I'll report back if any issues come up but as of now, the Orbi seems to be more of a victim of these issues than a cause of the network failure.
scttq
Jan 17, 2019Guide
Good to hear!
Orbi is in AP mode, ONT is a fios branded I-211M-L, fios router is the AC1750 (G1100).
Daisy Chain was/is enabled, I can disable.
I can temporarily go direct to the satelilite and see what happens, the same switch is also feeding the components on an AV rack. I hope it's not the switch as it's brand new, not sure what modern rack mountable switch doesn't have some green.energy efficient/smart tech in it.
Would there be a benefit to wiring the satalilite direct to the RBR50 and then runing the switch off the satallite ethernet port?
Jan 17, 2019Guru - Experienced User
Try disabling DS and see.
Try direct connecting the satellite and see what happens.
HP and D-Link have some non green tech switches. I think NG might still. I have a HP 1400 series 24 port rack mount. I also use other smaller switches in between as well. There all non green tech. :smileyvery-happy:
