scttq
Jan 17, 2019Guide
Anyone Successfully Using Mixed Wireless and Wired Backhaul?
Hi,
I've been using an AC3000 system (w/ 2 satellites) for about 1.5 years, been through some ugly times with constant disconnects but the platform really seems to have improved over the last y...
- Jan 23, 2019
It's been 4 days now and all is still good.
To summarize (based on my observations):
- I added an AV rack, rack switch and wired backhaul to my basement, previously was on wireless with everything working fine
- Day after this new setup, entire network went down
- Two seperate issues were discovered:
- Four Sonos components were hard wired to the switch, the components don't automatically disable their wifi connection and apparently introduced a network loop
- My Sony Android TV when connected over ethernet tends to cause a type of network storm over UDP because of a bug in the Chromecast feature. This was corrected for the wifi adapter but not the ethernet adapter.
I'll report back if any issues come up but as of now, the Orbi seems to be more of a victim of these issues than a cause of the network failure.
Jan 19, 2019Guru - Experienced User
Let ys know the results and try the incoming switch in place of the TP-Link as well. Just curious to see results of it.
scttq wrote:
Weekend update 1.
Sony Android TV is now on wireless, no issues so far. I'm not a huge Sony fan in general and this certainly hasn't changed my opinion. The actual ethernet post is only 10/100 and also prone to broadcast stroms when powering on due to some logic with the Chromecast feature. Seems silly as this was the top of the line 4k Sony when purchased.
Sonos units that are hard wired to the switch all have wifi turned off, there is also a Sonos Boost plugged into the RBR50.
Original TP-Link switch is still in place.
As of this afternoon, I plugged a Satallite into the switch, after removing it in the Orbi admin page. So far so good, will give it a few days before passing final judgement.
scttq
Jan 23, 2019Guide
