youngr1
May 24, 2019Aspirant
Anyone use satalites with haulback to extend the SSID or network (not expecting MESH accoss them)
Not sure why the RBK43-100NAR does not show up in the list so had to take the RBK53. Anyway I want to use the router and 2 satellites in my home and then I have 2 out buildings in my properties th...
youngr1
And in this mode the SSID would be the same and maintiain the same network schema?
CrimpOn
May 24, 2019Guru - Experienced User
Yes. One network. One router doing DHCP.
- youngr1May 24, 2019Aspirant
Thanks! Not sure if you saw my other questions. I would order 2 kits so would end up with 2 routers. I assume I could set the extra router as an access point? Also if I put to satiates in the same building not in the same one as the main one would work in MESH as the main site would?
