Ulairi
Apr 20, 2018Luminary
Anyone using RBW30 with RBK50 Successfully?
Per this thread, I am unable to get my RBW30 Wall Satellite to work with the RBK50 kit (RBR50 Router and RBS50 Satellite). It works okay for about three days, then starts causing disconnects. Power...
angr
Apr 22, 2018Star
Also have a RBW30 in my setup, and it's also whats been causing me most grief.
It's been wastly improved however since the new BETA, but I've notice that it has twize over the past 1,5 weeks dropped down to 2,4Ghz without any obvious reason (I actually have this Sat closest to the RBK50 router). A power cycle fixes it.
- UlairiApr 23, 2018Luminary
angr wrote:It's been vastly improved however since the new BETA, but I've notice that it has twice over the past 1.5 weeks dropped down to 2.4Ghz without any obvious reason (I actually have this Sat closest to the RBK50 router). A power cycle fixes it.
Thanks for responding. It sounds like your situation is different. Rather than disconnects, I presume that your RBW30 was still staying connected, even when it dropped to 2.4GHz?
According to the admin page, I have never been able to get my RBW30 Wall Plug Satellite to connect to the 5GHz backhaul channel. It doesn't matter whether the wall plug satellite is in the same room as the router, the next adjacent room, or a few rooms away, it consistently reports as being connected via the 2.4GHz channel for the backhaul. The latest firmware reports the connection as 'good' when nearby, but in the location where I actually want to use it (which is only one room over and on a lower floor with light timber framing between), it reports backhaul connection as 'poor'. My RBS50 satellite report 'good' connection from that same location.
The disconnects occur no matter which location the RBW30 wall plug satellite is in.
Also, my wall plug satellite has weird connection behaviour. With all the testing and changes in location, I've been turning the RBW30 off from the power a lot. When I first switch it on again each time, the RBW30 ring light goes solid white and stays on. I have to manually re-synch the router and satellite to get the RBW30's white indicator light to go out.
I'm being to suspect a hardware fault in my unit, but its interesting that you're the only one person who has responded about using a RBW30 with RBR50 and you are also having glitches, albeit different ones. The stability problems with this satellite don't make any sense because they must surely be compatible - the RBK52 is a kit that specifically has 2 of these wall plugs along with the RBR50 router?????
Does anyone have sucessful connection of a RBW30 Wall plug satellite to the RBR50 router?
