frustrateduser9
May 04, 2020Aspirant
AP and parental controls won't enable
I have to use the AP mode which apparently disables parental controls which is why I bought this product to begin with! Its incredibly frustrating. I've read a bunch of postings similiar to my is...
May 04, 2020Guru - Experienced User
Those controls are disabling in AP mode:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
If you need the Orbi to have those controls you'll need to configure the RBR for router mode.
IF you have a host route already in front of the RBR, you can use the host routers DMZ or IP pass thru for the RBR and configure the RBR for router mode. See option #2.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
What is the Mfr and model# of the ISP Modem or host router your using in front of the RBR?
