ShadowHead
Jun 16, 2019Tutor
AP Mode Vs Router Mode - DHCP Passthrough
Perhaps this was covered many times already. If I missed the post or failed to find the answer, my apologies. I am curious if ORBI RBR50 offers any option to pass DHCP requests from connected wir...
CrimpOn
Jun 16, 2019Guru - Experienced User
Using the web interface, on the Advanced Tab, LAN Setup, there is a check box, "Use Router as DHCP Server". Uncheck that box.
- ShadowHeadJun 16, 2019Tutor
Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
- CrimpOnJun 16, 2019Guru - Experienced User
ShadowHead wrote:Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
Please post what you find. I would try this myself, except my new modem is "only a modem." DHCP Discover is a broadcast packet, where the "to" MAC address is FF:FF:FF:FF. I would think that the Orbi is supposed to transmit that packet out every link.
- Fl1ntstoneJun 17, 2019Apprentice
Hi Guys,
You will need to turn DHCP back on as I don't belive DHCP passthrough is supported?
DHCP discover is a broadcast packet but that is only at layer 2, so will not pass through the ABR.
CheerZ
