ShadowHead
Jun 16, 2019Tutor
AP Mode Vs Router Mode - DHCP Passthrough
Perhaps this was covered many times already. If I missed the post or failed to find the answer, my apologies. I am curious if ORBI RBR50 offers any option to pass DHCP requests from connected wir...
CrimpOn
Jun 16, 2019Guru - Experienced User
Using the web interface, on the Advanced Tab, LAN Setup, there is a check box, "Use Router as DHCP Server". Uncheck that box.
ShadowHead
Jun 16, 2019Tutor
Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
- CrimpOnJun 16, 2019Guru - Experienced User
ShadowHead wrote:Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
Please post what you find. I would try this myself, except my new modem is "only a modem." DHCP Discover is a broadcast packet, where the "to" MAC address is FF:FF:FF:FF. I would think that the Orbi is supposed to transmit that packet out every link.
- Fl1ntstoneJun 17, 2019Apprentice
Hi Guys,
You will need to turn DHCP back on as I don't belive DHCP passthrough is supported?
DHCP discover is a broadcast packet but that is only at layer 2, so will not pass through the ABR.
CheerZ
